2 titan blacks vs 295x2
If sticking with two cards, 295x2. If considering a third card, Titan Blacks due to actually being able to use and benefit from more than 4gb vram.
If he's thinking of 2 cards he could even go for 2 x 290x and save some money, 2 x 290p and save even more!
I'd probably go for 2 x 290p or 2 x 780 6gb cards.
Of the choice, the two titan blacks
However, as some others have said, there are definitely other choices such as 2 290's etc :)
well hell be playing all the latest and greatest.
he is a bit more nvidia biased .
cost doesnt matter.
Can he wait for a month? Worth waiting for the new 880's to show up in September, see what they offer perhaps
He won't be running max details on anything that will break 4gb at 4k as 2 gpu's won't be enough to give decent frame rates.
I would personally go for some cheap 290p's until the next Gen arrives.
I did not know you knew the guy personally to know what he wants or will use.
If he got 2 titans and a gsync monitor I am sure the low fps would feel a lot higher.
I think they won't be available till November.
Ah, heard rumours of a September release - probably won't be in stock till November then? Either way, you can see if the specs/price appeal to you if you wanted, if not your friend could make another decision
