Those SMDs seem to be that colour by default:
I now have had 2 CPUs (i7 7800X Skylake-X) that have died in an identical way.
The first one died while waking from sleep in windows. This was in October.
Now I have had the replacement also die in a similar way, I woke it from windows while it was in S3 sleep and its also died.. it just turns on the fans and "00" is showing on the Debug LED.
When the first one died I changed both the CPU and motherboard.
No overclock, both on stock and default settings.
Now the replacement has died. What could be the problem ?
Did you solve your problem with X299 motherboard after change RAM ?
Sorry to drag up an old thread but this is really helpful having just had 2 x 9820x CPU's die in the same way as you on an MSI X299 board.
First time everything was working flawleslly, very mild 4.2 overclock with H100i cooling, temps all below 75c on max load (30-40 idle). One night i was gaming till 12am'ish and the put Windows to sleep. Next morning I turn the machine on, all signs of life (fans on, lights on etc) but no post and 00 code.
I pulled everything apart and rebuilt out of the case (to be sure it wasn't a short). I swapped tried all ram modules and an alternate PSU. Still dead. I bought a new mobo and once installed this still showed 00 code (Asus board this time). Basically as far as i could tell the boards just didn't register the cpu being there hence the 00 code.
I RMA'd the chip to Intel and credit to them within 7 days had a replacement. This was installed 2 weeks ago, again a safe 4.2 clock at 1.18v, temps solid and safe. No issues at all for 2 weeks and then Friday night after some games i put the machine to sleep and in the morning boom same thing. 00 code, no post.
My conclusion is that 'something' is killing the CPU. The PSU is 2 months old Seasonic Platinum Plus and all voltages output are as they should be. Ram is 3200 Corsair Vengance RGB 4 x 8gb + 4 x RGB light enhance kits.
My vcore on the latest bios showed as a staggering 1.888v which was clearly not true (I posted on Linus form: https://linustechtips.com/main/topi...tomahawk-artic/?tab=comments#comment-12943893) and HWInfo confirmed it. I wonder if however something was/is iffy there.
My worry is that if I RMA with Intel they will just assume i or the mobo is killing CPUs and will not honour warranty... I honestly don't think i have done anything out of the ordinary to influence it but man its so frustrating!
@sithlord - where did you get the info about buggy MSI boards and voltages?
Anyway the problem is your RAM the QVL list is only for defaults volts.
Really appreciate the reply.
Can you illaborate on this? I imagine you are saying that if i up the voltage on the CPU cores the ram is then adding extra current draw on the Vcore too or something?
Also did intel question you on the RMA? Like as in 'ok this is twice now you are clearly doing something wrong and killing our CPU's' sort of line?
