2007 iMac problem
2 Jun 2005
W.Sussex
My parents iMac (mid 2007 20" C2D, with Lion installed) has developed a fault. It will lose its internet connection randomly, which can sometimes be reset by turning off/on the wifi, or a reboot. Other times it will simply not reconnect, until some point later in the day. The iMac is connected to a BT infinity router, there is also a PC that is connected via wifi on the same desk, which does not suffer from the problem. As it does this randomly I think it probably points to a faulty wifi card (can these be replaced in an iMac?), unless someone can point me in a different direction.
You can get the wifi cards replaced, and sometimes the antenna cable can come lose as well so it could be something along those lines.
You should try the usual shiz for a quick fix though, couple of pointers below:
1 - Power Management Reset: Unplug everything, all peripherals + power cable, leave for 30 seconds and power back on.
2 - PRAM reset: Boot up and before the apple/chime hold down ALT + CMD + P + R and keep them down until it chimes 3 times. Then boot up.
- These 2 don't always fix things but it can't hurt to try them, and Apple will ALWAYS ask you to try these first.
3 - Check in System Preferences > Network. Under the list of different network connections, there is a little cog. Click that and choose set service order. Drag the airport/wifi connection to the top and click apply.
4 - Try a new user account for a couple of days and see how it performs. If you do that, follow step 3 before you start testing as well just to make sure you have optimal testing conditions.
That should get you going, it's a mid 2007 so it's not the youngest Mac in the world, and if you did an upgrade install rather than a fresh install of Lion you might benefit from a fresh install, but see how you get on =]
