Hi all,
New to this forum - hope you can help me find a solution for this problem.
I have a two year old machine, that used to perform really well, but recently been having trouble getting the FPS I was used to. Thought maybe an update to the Geforce driver would help, but it continues.
So thought I would do 3Dmark benchmark and compare, and my score is in the below 2% of same systems. Just did a complete reinstall of Windows, which didn't help.
Is there anything in the benchmark that stands out? Or anything you would recommend me try?
http://www.3dmark.com/spy/19816039
Also did a user benchmark, that could give some more insights.
https://www.userbenchmark.com/UserRun/42363133
What I have checked :
Fresh install of Windows
Updated BIOS on MB
PCIe running gen3
RAM is running in XMP mode
Power management in Windows and Nvidia Control Panel is set to Performance
G-Sync is off when running benchmarks
Updated BIOS on MB
PCIe running gen3
Temp seems a bit warm for a Stock clock card ... maybe time for a repaste and new thermal pads .
