- 6 Jul 2006
- co durham
as you can see in my thread what ive got,now will the 24" be to much for my 8800gts,or will it be ok or should i just go for the 22" to be sure cheers for any advice
C64 said:an ancient tn film
Iraklis F.C. said:mate TN is indeed an ancient tech. theres no doubt about it
C64 said:yes it has an S-ips panel
C64 said:spva s-ips whats the difference both are 8 bit its just better than the now
prehistoric tn film and just because i have a crt for gaming
you assume i don't own or have owned tft's i have had 2 actually
which have gone back after seeing how sub standard they are.
And i have one on the downstairs pc and yes it's just awful because
it's a now medieval tn film panel.
Flame/troll is non existent grammar, i did a google search and used spell checker.Klo said:I'm not trying to flame/troll or whatever its called, but could you please use some punctuation (eg, capital letter, full stops) just to make your post slightly more readable
Thanks
mrdbristol said:![]()
You are beginning to make me laugh at your posts .
From your sig, you are using a CRT.
What exactly is your indepth knowledge of TFT panels based upon , you haven't even got one !
Yes , S-IPS gives better viewing angles - This hardly makes TN film " Ancient ".
Yes , The Dell 2407 Range is the preffered range for many users.
This doesn't make all other screens 2nd rate / sub-standard options.
Untill you have used a few TFTs' yourself , and not solely based your opinion on what you read , then your comments are pretty worthless.
Mark
