** £25 OFF SAITEK PRO FLIGHT X55 RHINO **
  • Thread starter Thread starter rjk
  • Start date Start date
Sticking with my dual stick setup as I am left handed. T16000m and an old Sidewinder Precision Pro. Works brilliantly for Elite Dangerous. If I were I righty I would have bought one of these though.
We have a limited time discount on these of £25.
Offer ends Monday at midday.
Saitek Pro Flight X55 Rhino H.O.T.A.S. System @ £154.99 inc VAT
Military-grade Flight Sim Precision
Inspired by controls found within actual fighter planes, the next-gen X-55 Rhino H.O.T.A.S. System for PC provides utmost control over simulated aircraft. Built to the same exacting standards of Saitek's award-winning Pro Flight accessories range, the X-55 Rhino delivers a multitude of customizable options never before seen in an H.O.T.A.S. System. Whether flying a modern fighter, single- or multi-engine aircraft, or even a retro single-seat plane, the X-55 Rhino supplies all the control surface options required to achieve the exact level of aerial performance aspiring pilots demand.
Enhanced Stick Accuracy
During virtual flight – just like true flight – the accuracy of an aircraft's control surfaces is of paramount importance. The X-55 Rhino's control surfaces are incredibly accurate, courtesy of an all-new 16-bit aileron and a 16-bit elevator axis, each employing hall-effect sensors. Developed from the ground up, Saitek's 16-bit axis solution enables extremely precise flight.
Adjustable Stick Force via Advanced 4-Spring System
A ground-breaking, adjustable stick spring system allows pilots to alter the force required to move the stick. Four springs of varying resistance are included to provide a total of five different options. Choose the spring – or no spring at all – which best accommodates your style of flying.
Twin Throttles with Friction Adjuster and Throttle Lock
Using a twin-engine throttle controller is the only suitable method for manipulating a virtual twin-engine aircraft. The X-55 Rhino boasts twin throttles – ideal for situations in which your primary engine is disabled and you're down to one – and also provides the option to adjust the friction required to move them. And if your aircraft of choice is single-engine, a handy throttle lock effectively converts the twin throttles into a single unit.
Bonus Toggles and Rotaries on Backlit Throttle Base
Flight sim accessories used by today's virtual pilots require the highest level of control and customization. The X-55 Rhino showcases additional toggles and rotaries, not based on any particular aircraft, around the throttle base. Seven extra three-way toggle switches and two rotaries allow you to customize this H.O.T.A.S. System to your own specifications.
Individual USB Connectors
The X-55 Rhino's stick and throttle units each utilize their own separate USB connection, offering greater flexibility during customization. You're free to situate the controls exactly where you want them, without the need to keep them tethered to each other.
H.O.T.A.S. Configuration Software Enables Programmable Controls
Saitek's new software provides the ability to completely customize all of the X-55 Rhino's axes and buttons. On the axis side, you can adjust deadbands and response curves to fine-tune axes to respond just like an aircraft's real-life counterparts. On the buttons and toggle side, you can assign any number of in-sim directives, such as speed brake, flares, target lock and pickle weapon. The software also allows programmability for an array of mouse and keyboard commands – from basic single-key inputs to very advanced, timed, and macro commands.
Build the Ultimate Virtual Cockpit
Transform even a modest PC into a virtual cockpit and experience the staggering realism of different flight and emergency situations – complete with realistic weather and flight conditions. Using the X-55 Rhino as a foundation for Saitek's modular accessories, easily add Combat Rudder Pedals and a multitude of Switch, Navigation, and Instrument Panels to fully customize your flight simulator. Commercial or private, seasoned or novice, you have the ability to equip your flight simulation setup with all the essentials needed to vastly improve your skill set and muscle memory.
Product Includes:
- X-55 Rhino Stick Unit with USB Connector Cable
- X-55 Rhino Throttle Unit with USB Connector Cable and Green Backlighting
- Spring System with 4 Springs of Varied Resistance
Compatible with ALL Major Flying Games with the Saitek X-55 H.O.T.A.S. Configuration Software,
Was £179.99 Inc. VAT
Only £154.99 inc VAT.
ORDER NOW
Can someone tell me what is the movement spring on this? On my old saitek I had to use cable ties to lower tension and it worked great, if that make sens, now the movement is possible with finger push where previously if I did that it would flip, I can see same spring on this one is it very smooth and sensitive like in fighter jet :) or still hard and loose smoothness over time?
Thanks
Hmmm tempting ...at the moment I have the Saitek Cyborg F.L.Y. 5 Flight Stick..tried it with BF4 heli and jet...and its terrible to use
I went from a Fly 5 to this and this is amazing, lot more expensive but definitely worth it. The only thing i need to get used to is the number of buttons, i try and use them all then forget what most of them do :)
Keeping this going for a bit longer.
we also have this coming in stock tomorrow.
£30 off & Lowest price in the UK too :)
Saitek X52 Flight Controller And Throttle Joystick - PC (PS28) @ £99.95 inc VAT
The most fully integrated PC Flight Control System Precision engineering, ergonomic design and a detailed fusion of features deliver maximum aeronautical authenticity.
- Advanced programming provided by Saitek Smart Technology (SST) software
- Enhanced gameplay through intuitive Multi-Function display (MFD)
- Illuminated buttons and MFD - ideal for low light environments
- Rubber grips and ergonomic design for increased comfort and fatigue-free gaming
- Part metal construction for increased durability and authenticity
- Includes Roger Wilco Chat software - the ideal accompaniment for on-line multiplayer gaming
Was £129.95 Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
£180 for a flight stick does seem a bit steep but you pay for what you get I guess and as its been said other sites offering the unit cheaper means nothing if they can not supply. Thankfully I can not be tempted as I am left handed
