2500k overclock using a gigabbyte z68...missing CPU Vcore setting
12 Nov 2005
Although the basic principles are the same for the z68 as the p67 for overclocking the K chip some of the processes for upping the vCore and terminology isn't.
EDIT: See Neil70’s post and link below for a detailed guide.
This might help
http://forums.overclockers.co.uk/showthread.php?t=18338090
I wouldn't use DVID on the gigabyte personally for overclocking, it caused me a lot of grief, prime unstable... bsods in windows sometimes wouldn't even boot, even though the volts were generally the same as using load line level control. I stick with my settings which work perfectly for me atleast, might be the same generally on yours?
Great guide and resulting thread Neil79. The OP should be prime stable at 4.5GHz by end of tomorrow night (chip permitting).
Interesting about the DVID on the Gigabyte - having said that i've only clocked one z68 board and that was only 4.3GHz (for a friend) - so i didn't have to play around much with settings.
EDIT: In fact the thread I’ve linked to isn’t that helpful so will edit to read your above post.
