2600K overclock help temps etc
11 Jan 2011
Hi, i have started overclocking my 2600K I have got up to 4.7GHz with no problems.
My vcore is at 1.32
Heatsink is a noctua D14
I have stopped overclocking as my max temp is 72c.
I would like to push it more but I'm unsure on what's the max safe temp for 24/7 use?
No Idea about the D14 for me although the SB chips do tend to run relatively cool anyway.
Maybe try reseating it with new (maybe better) TIM.
That temperature is absolutely fine for that clock/voltage/cooler combination.
The tcase on the cpu is 72ºc (often wrongly reported as the max) but max temp is 98ºc.
What is your CPUPLL at, as if you lower it to 1.75 or 1.70 you might shave off a degree or two from the max temp you get under load.
i have a 2600k @ 4.8 with a D14, and i hit 72 max. so your not far off.
thats with MX4 TIM after 24hours folding.
Ok could someone check my BIOS settings and tell me if you would change anything to lower temps or anything you would change anyway.
Spec is
2600k @ 4.7
Asus p8p67 pro
Geil value plus (2x4GB) 1600MHz
Ai overclock tuner - manual
BCLK - 100.0
Turbo ratio - by all cores 47
Internal PLL Voltage - Auto
Memory frequency - 1600MHz
Epu power saving mode - Disabled
Dram timing control - 9-9-9-28-Auto
Load line calibration - auto
Vrm frequency - manual
Vrm fixed frequency - 350
Phase control - standard
Duty control - T.Probe
CPU current capability - 100%
CPU voltage - Manual Mode - 1.325
Dram voltage - 1.600
VCCSA - AUTO
VCCIO - AUTO
PLL - 1.700
PCH - AUTO
SPREAD SPECTRUM - DISABLED
Thanks
Not related to the temp, but you should be able to set your ram manually to 9-9-9-24.
You could try dropping your CPUPLL to 1.65 and your vcore to 1.320 and check for stability, it would be worth at least 1 or 2ºc
