2600k Overclock Temps
i get 60-65c in intel burn test at 4.6ghz 1.31v with a Thermalright Venomous X cooler with 2 fans
i thought a H100 is better than a Thermalright Venomous X cooler
I have my 2600k sitting at 4.8Ghz, 1.34v and my temps don't even hit 60 fully stressed with the H100 on its lowest setting, temps go as low as 51c on its highest setting (albeit, it sounds like a hovercraft at that speed).
500R case, rad mounted on the top with the two H100 fans and the rear case fan as exhaust, two front fans and one side panel fan as intake.
Three intake, three exhaust, and it works a treat! Something is not right here, unless your ambient temp is just high.
i think there are just some toasty chips around........my 2600k @ 4.3ghz gets upto 63 degrees running prime.......this is on a custom loop where the the gpus only hit a maximum of 55 degrees in x fire......
cpu is @ 4.3ghz @ 1.260v (set on auto)
cant get it past 4.3ghz either.......something im doing wrong or the chip isnt a good clocker.......
None of these temperature claims mean anything without screenshots ;)
