- 26 Nov 2009
Hello. I'm looking for 27" 1440P and 144Mhz monitor strictly for gaming. Any recommendations please?
Dell S2716DG, LG 32GK850G
Probably wouldn't bother looking at anything else.
The Dell is the cheaper of the two ordinarily.
Edit: just realised you're not necessarily looking for a G-Sync monitor.
Which GPU do you have?
That Dell seems to fit my requirements, thanks. I'm using a GTX 970 ATM but looking to get a 2080 when released.
Do some shopping on the Dell and you can save almost £250 on OCUK price - not sure how they can be so far from others.
Asus warranty puts me off but you're right it's a quality monitor.
Frustrated that I was about to buy one of these having seen it reduced to £450, but the morning I went to order it, the price was back up to £550. Will wait until it's reduced again unless there is an equal alternative for around £450.I have the Dell S2716DG and I'm really happy with it, just make sure you change the out of box settings. A quick google wand you will be good to go
