Yeah, that's showing your 2D clock speeds, When you start a game or some other 3D app, they will speed up to around 750Mhz/850Mhz or something. If you get AMD GPU Clock tool, you can see the speeds for your 2D and 3D environmentsSone said:just bought one of these, first Ati card since 9700pro.
My fan seems resonable quite only really played stalker on it yet though. Can i just ask are clocks in ccc info realtime? my core and memory seem to be quite low clocked. (500ish mhz)
.Ghosteh said:What does your GPU temp idle at when its at stock volts and stock fan speeds? See mine sits at around 45-50C idle when its just on Desktop, and when gaming, it doesn't go above 70 very much, only in very intense scenes in stalker when above ground etc. Maybe I've just been very lucky lol.
Avatar261 said:hmm, i use ATITool.
What i am saying is that without ATITOOL open, on desktop the temp is going above 70c.
Should the temp be getting to 70c on the desktop?
Hmm just double checked using GPU Tool and ATiTool together. Deffinite 2D Speed of 506/513 is idling at 70c which would be why the fan speeds up to 38%
Should i be worried about this or is it just normal?
Clock.it/Ghosteh can i have your MSN to chat to you about it?
