Explosivo said:i'm wondering the same thing.
but i think all nvidia owners will tell you one thing and amd/ati will tell you an other.
i'v been trying to find out the answer on the net for ages.
my conclusion (from what i have read) is that if you want performance for the price in dx9 go for the gts.
performance for price in dx10 2900 xt ***.
and i still cant decide![]()
performance for price in dx10 2900 xt f.t.w
MaXXeH said:just waiting to click check out![]()
Tute said:I would say...
Vista = 2900XT
XP = 8800GTS
i dont even know what that is lol.MaXXeH said:my current card is mx440![]()
Tute said:Let me expand on this a bit.
The 8800GTS and 2900XT are pretty much neck and neck in performance, except that when AA is turned up, the GTS opens a rather sizeable gap.
The GTS is also quieter, cooler, and uses less power.
However in the drivers department ATi has the upper hand, especially in Vista, where they've been working hard. nVidia's release schedule is sporadic at best. The nVidia XP drivers are said to be quite good though, hence what I posted.![]()
MaXXeH said:lol no it is agp
i went for the
EVGA 8800GTS 640MB KO ACS3 Dual DVI HDTV PCI-E
better be good!!
the_champ_101 said:but at this level it's all about AA 'TURNED ON'! otherwise get a mid range card!
Also if the ATI driver department is so good why can't they solve all the crippling issues that comes with the 2900? e.g. fogging in source engined game or massive slow down in HDR enabled setup and AA!?!?!?!?
Tute said:Because they're working on it. I, having been an ATi owner for the past couple of years, and seeing what their Catalyst team can do, have absolute faith that most, if not all of the bugs will get ironed out.
Plus there are regular monthly driver updates, each one bringing more performance.
I admit, the AA performance hit is nothing short of embarassing for them, and I don't think it will be fixed in drivers. But also, it depends what kind of gamer you are - I personally run most games with 16xAF but no AA as I don't notice the IQ but I do notice the extra frames it gives.![]()
