- 18 Jan 2007
- UK, Sussex
Well it's either both parties are lying or both cards run really hot, in which case I
might as well turn back to my X1900XT
the_champ_101 said:Well it's either both parties are lying or both cards run really hot, in which case I
the_champ_101 said:I am a source engine game expert and I need this engine to run properly for the visuals and physics in order to play cs:s at my required standard, I can tell you if I feel the game hasn't changed from the X1900XT then its not a problem like you are suggesting, if theres no problem in the first place then I can't get rid of something thats not there, use your brain for god sake.
Link: http://www.rage3d.com/board/showpost.php?p=1334960724&postcount=8Yes, this is an incompatibility with fixed function fog for DX9 and new DX10 fog. The other company had the same issue. We're finishing up a driver work-around (no perf hit) and hopefully it will be out soon.
RostokMcSpoons said:Sorry about the big image - I don't know if it's possible to size it differently...?
Cyber-Mav said:my x1900xt manages that game at that rez even with AA on. so no miracles performed by the 2900 in that department.
, I am waiting for call of duty 4 and crysys hence the big upgrade.
welcome here m8ashmanuk67 said:Hi all my first post![]()
So many talk about getting the hd2900 and if its crap then get another high-end card, well for me i can only afford a good card once every 2-3 years.
Some ppl just have to much money![]()
I SO WISH IT WAS EASY LOL![]()
the_champ_101 said:After all this debate about the 2900 and its issue, I received my HIS one yesterday from overclockers and I have to say all the critics were right! The graphic card's performance is not great and runs quite hot even when the fan is spinning at 100%!
First the performance: it's ok on games with mainly polygon processing rather than
processor calculations, e.g. good = War Of Warcraft or if you want more demanding: Test Drive, bad = C&C3 or Rollercoaster Tycoon when you fill the game with units and the cpu is heavily loaded this card is really poor which might suggest why most of the benchmarks favour the G80 series with max AA and high resolution. The overall picture quality is sublime as you'd expect and the fogging issue is non existent on source engine games e.g. HL2 Episode 1 or Loast Coast, didn't know what the fuss was all about, hey maybe some of you need a new monitor which can display the games properly lol.
Overclocking is not an issue and the 8-pin connector worry is also no problems, but I must say at these temperatures I wouldn't stretch the card too far in the coming summer months. The fan isn't as loud as I feared running at its maximum but not as quiet as my old 1900 and also not as quiet as most G80 I've heard, although if both fan was at 100% I say this makes slightly less noise, ATI needs to fix the issue.
Overall I think the card failed in the attempt to beat the 640MB 8800 GTS at a lower price, If you are a ATI/AMD loyalist then this is an option but in real life gaming then I suggest people with their G80 series to be settled and wait for new candidates such as the 65nm R650 or even the G90.
I for 1 will send this thing back and follow in Esi's step and get a 320MB GTS to tie me over until a G90, wise move my friend.
evilcrowuk said:Your full of it, i bet you don't even have the card, just some random pleb talking balls. The fact you say that there is no fog issue in valve games shows you know ********..![]()
