- 23 Mar 2009
- Peterborough
OcUK did list the NEC MultiSync EA231WMi-BK however have taken it down, Was IPS 23" with display port and 100 quid cheaper than the Dell. Doesn't seem to have the tint issues dell seem to be suffering with. however i think dell are sorting this issue now plus the issue only seems to be affecting/noticed by few however it put me off getting one.
As for the people shouting "waste of money!" please go away it's hardly constructive, £2000 for a pc including a monitor isn't too bad, infact i'd say it's a good budget. I'd advise buying now rather than waiting otherwise you'll be forever waiting for something, by the time you wait for the new cards something else will be on the horizon.
I can't do you a spec as i'm at work but i would advise going for an i7 920 setup with an SSD for boot and an f3 for storage. and perhaps a 5850 for graphics as they are a better option than the 5870 in terms of value plus you can always get another later if you need to. I would also advise getting something like a lian li case as they will last you forever. If you pick your components carefully should be able to get it with enough change to get some nice new peripherals or something.
