Probably not that big of a deal for most but seems that 2 way is the way forward for multi gpu now. Some benchmark apps will have support, not games though.
http://www.pcper.com/news/Graphics-...3-Way-and-4-Way-SLI-will-not-be-enabled-games
I just hope this means 2-card SLI gets better support now.
It doesn't affect me personally, but the timing is interesting. Would this be down to a technical limitation on their side somewhere, or resistance from devs or what?
I hope we see a full revision of SLI soon. The current method has been unchanged for 12 years, and frankly sucks.
Glad they're ditching 3/4-way though, it's a move in the right direction and considering how poor the gains from those extra GPUs are, it's practically consumer-friendly.
How wrong you are.
I expect to see good 4 way SLI in quite a few games with the 1080s.
This is quite an easy statement to make as there is very good 4 way scaling in a number of the latest games. Unfortunately most people don't know this as they are not in a position to test it.
Something people should be very concerned about is DX12 based games as mGPU support is left to the devs. Unfortunately all the game devs care about is making money and this can mean no mGPU support at all and that includes 2 way.
If 3 and 4 way support does go it will very likely be that 2 way support goes too.
Can't see it to be honest, Gotta remember people who use 3 or 4 GPU's in the same system are the extreme minority so from a developmental standpoint it's just not worth putting time into it were as 2 way is, Plus after 2 card the gains start to slip off pretty quickly.
The gains are very good beyond 2 cards actually. The reason you don't see this in reviews is they use the same settings as they would for a single card and end up bottlenecking the CPU.
With DX12 mGPU support will not be up to NVidia, it will be in the hands of game devs and they could use 8 way SLI if they wanted to.
How wrong you are.
2 way sli is nuff. 3 way and 4 way sli is a very very small % of all nvidia setups. its not worth to develop for them
