Yep, and it makes sense to focus on the most common set up. Coding for more than 2 cards is surely coding for less than 1% of it's consumer base?
They can create a code path in drivers that is optimised for and focuses on Dual setups. So it simplify's the problem as you have less variables to take into account. therefore it should provide better performance overall for bolt on the top DX11 and OpenGL dual GPU setups.
