z0mbi3 said:3 displays is not possible on a single card (at least not the sort your looking at). Best bet is to get something like an old geforce 2 pci and use that for one of the displays.
My monitor history has gone something like this:
1 crt
2 crt's
1 tft
2 tft's
3 tft's
1 tft & 1 widescreen tft
Now I'm thinking about going back to 1. I'd say 3 is definitley OTT though.
feriso said:Yes it is - a while a go someone used a triple head adapter to run three monitors from a single source - albeit spitting a single resolution across three monitors rather than three individual 'desktops' so to speak.
edit : here's one - or search for triplehead
z0mbi3 said:I would have mentioned that device but it seems far from ideal tbh. I only really saw their advantage being for gaming, but even then its so so. I definitley wouldn't recommend it to the up.
It's much more feasble to get an additional gfx carf for £15.
feriso said:I was just being predantic and answering the OP's question![]()
Tens said:how does it work then, just throw it intot he pci and conect the monitor to it?
how does windows deal with it
on the go-l canyon series! they are monsters think they cost a lump tho!harris1986 said:i have seen 4/5monitors all used for one desktopon the go-l canyon series! they are monsters think they cost a lump tho!
Tens said:so just to clarify.
I run 1 crt VGA from my x800xl and svideo component out tihngy to my LCD tv.
All i have to do is put in a cheapy pci card (ati as dan said above) connect my 3rd monitor, goto display settings and it will show up with 3 screens.
and yea itll be fine.Tens said:yeh its got a DVI out, but can a card only handle 2 outputs at a time?
Sirrel Squirrel said:It can not do all 3 at the same time, I have an X800XT connected to 2 TFTs and a TV, I have to disable the 2nd monitor to get a picture on the TV, it's beacause the card only has 2 output heads. You will have to buy a PCI VGA card to get a 3rd output.
