3070 power supply/connectors advice please :)
2 Dec 2020
Hi, my current power supply has a 6+2 pin to 8 pin connector which I used with my 2060super but I managed to get a 3070 which has an 8pin so that works across fine but also a 6 pin slot. My PSU also has 2 4 pin molex and 2 sata 15pin slots I could use to connect the 6 pin slot on the GPU with if I bought a connector. Are either of those(the sata to 6pin especially) fine for the GPU or do I just need to find a more suitable power supply of some kind. Or any other suggestions any help is greatly appreciated thanks my last pc was built by OC so I'm pretty awful with this stuff.
3 Feb 2017
Mondas
Use the 6 + 2 pin you will be fine. Don’t use any converters. How old is your power supply and what is it by the way
