3080 replacement thermal pads question..
31 Aug 2021
Suffolk
As per title..
What are the recommended brand of thermal pads for such a card?
I'm replacing them because I need to split the card to fit a new fan that has arrived today.
You need to check the other thread round here. I think depending on when you bought you need thicker or thinner pads.
I bought extreme 2.0 (die side only plan) but never used them as I went straight to a block in the end.
So I can't say if they would work on my card with a date stamp of 18-06-2021
