Interesting, my old 1080ti and 7700k would have the GPU pinned at 99% in BFV so I just assumed the new hardware would be the same.Some games are FPS or CPU thread limited. So if the game has some code that is slow/clock locked to the compute/ai/etc, then the FPS can hit a hard limit.
Especially true in some driving games where framerate was locked as it's physics calculations are locked to framerate. Also true for some other games (IIRC Fallout 3 had this).
Without knowing the games code though, hard to accurately speculate.
Hi ish, 3440x1440 UltrawideWhat do you mean "hi-res"?
Just pointing out that I should be taxing the GPU enough in game but clearly I'm not.
99% of what?Interesting, my old 1080ti and 7700k would have the GPU pinned at 99% in BFV so I just assumed the new hardware would be the same.
99% useage, as in GPU useage.99% of what?
Percentage is a measure of use, not unit. 99% at what fps, and what resolution? 99% of what compute ability vs the 3090? It could be the game engine not understanding how to use a 3090 (mistaking 24gb vram for 2gb vram due to poor coding not allowing 2 digits of ram utilisation and just reading "2.4" in error, but rarely does that happen nowadays, more a 1990s/2000s game engine problem).
A Nissan Micra doing 99% performance might be it going 80mph, a Porsche doing 80mph is only like 49% performance. So if the road is limited to 80mph, you'd get the same result as a 3090 and the game being limited to 160fps.
"Fair enough, I just seem to remember all my GPUs always sitting at 99%, maybe I've just been hammering them all along lol."
Then you were not CPU limited, but GPU limited. Now you are CPU (or game engine) limited. You mistook 99% to *be* the unit measurement. It's not. It's telling you the GPU is working full speed, but not what that speed is.
PS, providing you are getting the FPS results though. If your getting 50% gpu use and only 30fps, then something is wrong. That's when you look for power failures, bottlenecks or driver/game bugs.![]()
Must be game related as it's 99% usage in Unigine Heaven with a benchmark score of 6313 (250fps) (High Preset at 3440x1440)
That particular game (BFV) must not be loading CPU/GPU up enough then?
I always thought GPU would run at 99% usage all the time no matter what?
This is what I thought, I've played some Cyberpunk and the GPU usage is pinned at 99% as expected, with CPU at 30-40%.If using vsync or a hard fps cap then yes then pretty much normal, if not and it’s off then it should be at 99% or there abouts even with an RTX 3090.
Id find it hard to believe that the 11900k couldn’t keep up with it especially at 3440x1440. Especially to the point of only using 40-60%.
Make sure you’re using normal DX11, DX12
On BFV is usually just trouble and never has ran right.
You think I'm not taxing the new hardware enough? That did also cross my mind. I did try ray tracing but it just made the game jerky and the FPS went to 80. Can't use DLSS on BFV because it's DLSS v1 which does not support Ultrawide resolutions. I could try upping the Res scaling in game to see what that does.use higher resolution scaling options
or use DSR
Point: Whoosh.99% useage, as in GPU useage.
