I think you are on to something there, I put the Res scale up to 130% in game and GPU usage stays at 98% at around 120fps untill the FPS gets near 200 (which is the max FPS BFV can do), at this point the GPU useage backs off to 70-80% because it's hitting BFVs hard cap of 200fps. I think it's just boils down to BFV not being taxing enough for this GPU at 100% res scale.use higher resolution scaling options
or use DSR
you're cpu bottlenecked near 120-160 fps. this is pretty normal and common with nvidia gpus. they eat %20-30 more cpu so your cpu bound max ceiling fps will always be lower than AMD gpus due to nvidia's hack
conisider urself lucky if that cpu can hit 100-110 fps in bf 2042 lmao. that game will be designed to push 120 fps with zen 4+ddr5 in mind
oh disable dx12
That was with DX12 on but yeah I'll go back to DX11 because it's definitely smoother.
Although this doesn't explain the initial CPU bottleneck it does somewhat put a bandaid on it for now.
