Asking for advice please from the experts here for a new monitor. A few requirements/thoughts below:
Budget: £800, could stretch a bit more.
Purpose: Work daily, and some gaming. Don't need super-fast refresh rates as I'm not competitive and don't often play FPS - mostly Elite and Star Citizen (so blacks are important), Total War and similar. Bit of FPS getting humiliated by my lad.
Size: I can fit up to a 36" monitor, though doesn't need to be that big. 32" or 34" could be the sweetspot.
Resolution: 4k is nice and my GPU could cope, but 1440p or whatever is fine and it might keep Windows happier, or make running dual monitors easier?
G-Sync: Yes
Curved or flat: Not sure. Never had a curved monitor, and I guess I'd prefer a flat screen but open to advice.
Screen technology: Advice welcome. I've always used IPS but I'm well out of date on all this.
Other stuff: I appreciate solid build quality. Currently use an NEC which is built like a tank.
Contenders: Alienware AW3420DW? An LG jobbie?
All advice gratefully appreciated!
G-Sync: Yes
