3200mhz Memory Overclock
Memory o/c been running fine for several days - passes memtest fine
Just checked benchmarks in AIDA64 and get these results:
Read - 56455 MB/s
Write - 30389MB/s
Copy - 53263 MB/s
Latency - 67.6ns
The 'write' looks very low - or is this ok?
CL 16
RCD 16
RP 16
RAS 32
Read - 56455 MB/s
Write - 30389MB/s
Copy - 53263 MB/s
Latency - 67.6ns
CL 16
RCD 16
RP 16
RAS 32
The write is normal for 3000 CPUs with 8 core or less.
Can you explain how you have 3800 running without being halved? I thought the max was 3733 for 1:1 if your silicon was good?
Are you using all the values provided by Ryzen DRAM Calculator?
Tried here, was fine for gaming, normal use, but crashed during memtest.
I started with the values from the DRAM Calc - but fast settings at first were not stable and gave me errors (I did have a major issue at first, causing me to re-install W10 as could not recover no matter what I tried (wasted a full day on it as well)).
A weekend of tweaking and retrying solved it for me = now stable and passing all tests.
