It shouldn't do because 10 x 230 with RAM on a 166 divider puts the RAM at 191MHz and therefore not even at stock. Reset the CMOS, then when you're ready to try again, I would try upping the vcore up a notch.str said:Try the 133 memory divider and 240 HTT just in case 166 makes the board run the memory at tighter settings making it unstable as the overclock takes it back up to 200. I have my memory settings configured manually to get around such problems.
