anyone taken into account of dram tempratures, if the heatsinks get close to 60 degrees with no active cooling then that can cause laggy behavior in the bios and especially in windows, i have teamgroup 3600mhz ripped ddr4 kits (x2) on my 5950x build and i can tell you at 1.45v my modules run very warm in the upper 50's acording to my temp sensor which is attached to dim 2 under gaming or benchmark loads, if i try upping the voltages to overclock the ram a bit more temps go up to almost 60 and if i dont actively cool the ram i get lag not so much in the bios but in windows it's terrible, i just back down to the dims rated 3600mhz speed and remove the fan, sure my dims run warm but i dont have any problems.
if you want to keep your overclock setting on the ram i'd sugest active cooling on the ram 1.4v for long term use on ddr4 is very high and going close to or at 1.5v long term isnt really recommended if you can help it, hot running ram and the imc on the cpu gets stressed more.
