3930K @ 4GHz - x40 AutoV?
No worries!
I just received the other 32GB pack back from RMA, they replaced it.
So I guess if these have errors when placed individually at stock settings then it will be conclusive that it is not an issue with the RAM.
I honestly dont think all 8 sticks could ever be all faulty. Its a board, bios or CPU IMC problem this.
I think its most probable that the AUTo settings detected during memory training are not stable settings and you will need to post them up so I can trouble shoot.
Yeah, I agree. I put all 8 sticks in last night and system is stable as it was before with the OC, but still memtest errors and not passing max intelBurntest or Prime95.
I will post the settings tonight, sorry for the delay mate had a few issues at work Ive had to work on.
I'll had type them all for you rather than screen shots.
Oh and also, as a thank you for looking into this mate - if you are on O2 for your mobile, my fiance works for them and I can stick a 30% F&F discount on your account for you. If your not on O2 then please accept a internet 'fist bump'.
If you are send me a message on my website. Just google my name and it will be the first hit: 'Kristopher Fisher Audio'. (I have not idea if you can PM on this forum!)
Thanks for the offer mate.
I work for OCUK and this section is where users get to ask me the number one ranked overclocker in teh UK anything and I try to help.
I get your system up and running and a satistied customer is all I am looking to gain.
Again the offer is much appreciated though.
Here you go mate, have a gander!
BIOS Settings:
MIT
BCLK/PCIe Clock Control - Auto
Host Clock Frequency - 100.00MHz
Processor Base Clock (Gear Ratio) - 1.00x
BCLK/PCIe Clock Evaluation - 100.00MHz
CPU Clock Ratio - 40
CPU Frequency - 4.00GHz
Extreme Memory Profile (X.M.P) - Disabled
System Memory Multiplier - 16.00
Memory Frequency (MHz) - 1600MHz
Advanced CPU Core Features
Internal CPU PPL Overvoltage - Enabled
Real-Time CPU Ratio Control in OS - Enabled
Intel(R) Turbo Boost Technology - Enabled
Turbo Ratio (1-Core Active) - 40
Turbo Ratio (2-Core Active) - 40
Turbo Ratio (3-Core Active) - 40
Turbo Ratio (4-Core Active) - 40
Turbo Ratio (5-Core Active) - 40
Turbo Ratio (6-Core Active) - 40
Turbo Powe Limits (Watts) - 500
Core Current Limit (Amps) - 300
CPU Core Enabled - 6
Hyper-Threading Technology - Enabled
CPU Enhanced Halt (C1E) - Disabled
C3/C6 State Support - Disabled
CPU Thermal Monitor - Disabled
CPI EOST Function - Disabled
Advanced Memory Settings
Performance Enhance - Extreme
DRAM Timing Selectable - Expert
Profile DDR Voltage - 1.05v
Profile VTT Voltage - 1.05v
Channel Interleaving - Auto
Rank Interleaving - Auto
Channel A Timing Settings
Channel A Standard Timing Control
CAS Latency - 9
tRCD - 9
tRP - 9
tRAS - 24
Channel A Advanced Timing Control
tRC - Auto (39)
tRRD - Auto (5)
tWTR - Auto (6)
tWR - Auto (12)
tWTP - Auto (24)
tWL - Auto (8)
tRFC - Auto (240)
tREFI - Auto (12)
tRTP - Auto (6)
tFAW - Auto (24)
Command Rate (tCMD) - Auto (2)
Channel A Misc Timing Control
Round Trip Latency - Auto
Channel B Timing Settings
Channel B Standard Timing Control
CAS Latency - 9
tRCD - 9
tRP - 9
tRAS - 24
Channel B Advanced Timing Control
tRC - Auto (39)
tRRD - Auto (5)
tWTR - Auto (6)
tWR - Auto (12)
tWTP - Auto (24)
tWL - Auto (8)
tRFC - Auto (240)
tREFI - Auto (12)
tRTP - Auto (6)
tFAW - Auto (24)
Channel B Misc Timing Control
Channel C Timing Settings
Channel C Standard Timing Control
CAS Latency - 9
tRCD - 9
tRP - 9
tRAS - 24
Channel C Advanced Timing Control
tRC - Auto (39)
tRRD - Auto (5)
tWTR - Auto (6)
tWR - Auto (12)
tWTP - Auto (24)
tWL - Auto (8)
tRFC - Auto (240)
tREFI - Auto (12)
tRTP - Auto (6)
tFAW - Auto (24)
Channel C Misc Timing Control
Channel D Timing Settings
Channel D Standard Timing Control
CAS Latency - 9
tRCD - 9
tRP - 9
tRAS - 24
Channel D Advanced Timing Control
tRC - Auto (39)
tRRD - Auto (5)
tWTR - Auto (6)
tWR - Auto (12)
tWTP - Auto (24)
tWL - Auto (8)
tRFC - Auto (240)
tREFI - Auto (12)
tRTP - Auto (6)
tFAW - Auto (24)
Channel D Misc Timing Control
Advanced Votage Settings
3D Power
PWM Phase Control - Auto
Vcore Voltage Response - Auto
Vcore Loadline Calibration - Auto (+60%)
IMC Voltage Loadline Calibration - Auto (0%)
DDR CH (A/B) Voltage Loadline Calibration - Auto (0%)
DDR CH (C/D) Voltage Loadline Calibration - Auto (0%)
CPU Vtt Loadline Calibration - Auto (0%)
Vcore Protection - Auto (375.0mV)
DDR CH (A/B) Voltage Protection - Auto (375.0mV)
DDR CH (C/D) Voltage Protection - Auto (375.0mV)
Vcore Current Protection - Auto (100.0%)
CPU Vtt Current Protection - Auto (100.0%)
IMC Current Protection - Auto (100.0%)
DDR CH (A/B) Current Protection - Auto (100.0%)
DDR CH (C/D) Current Protection - Auto (100.0%)
Vcore PWM Thermal Protection - Auto (130.0 Degrees)
DDR CH (A/B) PWM Thermal Protection - Auto (130.0 Degrees)
DDR CH (C/D) PWM Thermal Protection - Auto (130.0 Degrees)
CPU PWM Switch Rate - Auto (500.0KHz)
IMC PWM Switch Rate - Auto (250.0KHz)
CPU Vtt PWM Switch Rate - Auto (250.0KHz)
DDR CH (A/B) PWM Switch Rate - Auto (250.0KHz)
DDR CH (C/D) PWM Switch Rate - Auto (250.0KHz)
CPU Core Voltage Control
CPU Vcore - 1.310V (1.335V)
Dynamic Vcore (DVID) - Auto (+0.000V)
CPU Vtt - Auto (1.050V)
CPU PPL - Auto (1.810V)
IMC - Auto (0.900V)
DRAM Voltage Control
DRAM Voltage (CH A/B) - 1.500V
Data Tx Reference (CH A/B) - Auto (0.750V)
DRAM Termination (CH A/B) - Auto (0.750V)
Data Reference (CH A/B) - Auto (0.750V)
Address Reference (CH A/B) - Auto (0.750V)
DRAM Voltage (CH C/D) - 1.500V
Data Tx Reference (CH C/D) - Auto (0.750V)
DRAM Termination (CH C/D) - Auto (0.750V)
Data Reference (CH C/D) - Auto (0.750V)
Address Reference (CH C/D) - Auto (0.750V)
Chipset Voltage Control
PCH Core - Auto (1.100V)
PCH 1.5V - Auto (1.540V)
Wow! That's a lot of lines, hope that's okay for you buddy.
Cheers!
Yeah no problem. Next question I have though is this the settings with 64gb installed???? especially memory timings??? Then I can see exactly how to help.
Yep this is with the full 64gb installed - all 8 slots filled with one 8gb stick each and all identical Ram.
Posted from Overclockers.co.uk App for Android
Yes, still errors regardless of setup:
1 stick at a time CH-A.
2 sticks at a time CH-A.
4 sticks in CH-A/B.
8 sticks in CH-A/B + C/D.
I have tested with the replacement ram on its own also. I highly doubt that what is effectively 12 sticks of ram (original 8 + replacement 4) are all faulty haha.
Also just a note mate:
When I had stock settings and 8 sticks in a would get BSODs all the time.
Then when I had 4 in the amount of BSODs reduced but I would still get them.
Then when I put the OC on at played about I would have no BDOS - I would only fail the maximum test of IBT or Prime95 after an hour.
Since I have put all 8 stick back in I have also had NO BSODs what so ever.
So what I am trying to say is since the current OC settings which I posted up have been applied I have not had any BSODs or restarts etc of any kind. I only fail torture tests etc at max settings.
IBT is crap!! I said ages ago forget this POS. Even intel dont use it!! It places ridiculous stress on the Silicon and is more a cpu killer than a stability test.
Memtest is the interesting one here. Lets try get this one stable.
Set the following numbers working down your bios for each channel:
9-10-9-28 auto Make sure Command Rate 2T
Then set
tRRD 6
T Ref Cycle Time 296
tWR 16
tRTP 20
tFAW 40
tWTR 20
tCKE 6
tWCL 8
Memory Voltage 1.6v
VTT 1.15
IO 1.2
See how this goes and report back!!!
Okay, 9-10-9-28 set.
Command Rate (tCMD) is set to 2
As for the other settings:
tRRD is set to 6
T Ref Cycle Time - there is nothing that says this? Is this what tRFC is?
tWR is set to 16
tRTP is set to 15 - You said 20 but the max it allows is 15.
tFAW is set to 40
tWTR is set to 15 - You said 20 but this max it allows is 15.
tCKE - there is no option for this, not mention of it anywhere.
tWCL - there is also no option of mention of this in the BIOS.
Also VTT - Do you mean CPU VTT or Memory Profile VTT? (Profile VTT is grey'ed out in the memory section)
IO 1.2 - What is this?
Cheers - Kris
