3930K W/W Poor Temps?
24 Aug 2007
Hi 8Pack
My watercooled 3930K seems to require 1.35v to maintain 4.5Ghz which seems rather poor. I have set LLC to high, voltage to 1.35 and can pass IBT / Prime etc with temps hitting high 60s
it seems like a high temp given what i would consider a very good watercooling setup, and my CPU seems to require quite a lot of volts for what is surely only a "good" overclock
If you can give me any pointers it would be MUCH appreciated
System specs below
Asus Rampage Extreme IV
3930K CPU
360mm Alphacool Monsta radiator
240mm EK radiator
Switch 810 loaded with Ap-15 Gentle Typhoons (fans on top of rads pulling)
Each chip not only requires different voltages to reach a certain frequency they also all have different thermals.
I would try reseating the block first to check how the contact is. Do this using a good quality TIM.
I would also loose all that LLC go to medium. See how you go with this first.
It is worth it yeah. I am not keen on that TIM it scratches the IHS. The problem here is more than likely that you are using 8 dimms. This means more heat from IMC.
Try it just as an experiment remove six dimms so your just dual channel. Note your temps!!!
OK i have it stable at 4.5Ghz which isnt wonderful (before i try reseating TIM)
125x36
VTT is 1.150
VCore 1.35 in BIOS (1.32 in windows with medium LLC)
CPU PLL 1.881
CPU VCCSA 1.159
Temps hitting 70 degrees using IBT
My cooling setup should surely be better?
What speed is the RAM running at in your 4.5 stable????
This can effect overall CPU speed but help with efficiency of a certain clock.
I've kept the RAM running at stock 1600mhz as i thought that getting the CPU stable before the RAM would be wise
I'm going to reseat the block tonight as i really think that the watercooling setup i have should be doing a much better job
Nope!! Current 3930K need more Vcore in my experience!!! and I have a lot of experience!!!!!!!!
Yes that is a decent overclock although all things are relative.
What RAM speed you doing for this clock?? 2333mhz, 2000mhz??? Your clock may be more efficient losing 1 multi and running less Vcore with highly tuned RAM.
Also IBT proves nothing only you can run IBT, use your system to check its true stability.
Finally Intel recommends 1.4v as the top voltage for 24/7 use. I think I should point this out just so you know where your at with it. I am telling you to lower the voltage no!!! thats your call .
RAM speed is still quite low but looking at starting overclocking tonight
Any tips on what i should try out for? Would be nice to get around 2400mhz but i know now all RAM will reach those speeds. Or is a slower speed with tighter timings better?
