3930K W/W Poor Temps?
High Mhz with good timings.
Samsung Green try 10-12-12-25 1T Rampage Mode 1 at 2400mhz first. With 1.65v
Ok first go mode 2 and test. Then try get the seconds to 5,96, auto, 10,6,26,6,8. Tune TRFC first then the others with this try 121 first then 114 then 107 and finally 96.
Then try Tras 21.
Hi,
Thanks for the info, i just want to make sure we're talking about the same timings so i don't stuff this up!
Here is a screenshot of my memtweakit
when you say 5,96, auto, 10,6,26,6,8 then i assume you mean
RAS to RAS = 5
DRAM REF = 96
DRAM ref interval = auto
i'm unsure if you want the 10 to be in tWR, 6 in tRTP, 26 in tFAW, 6 in tWTR and 8 in tCKE
Dont want to put the wrong settings in the wrong place!
[/IMG]
You cant stuff it up only try!!! Its only a bios reset!!!
Going down mem tweak it.
5, 96, auto, 10 or 12, 6,26,6,6 then tune to 5, 8.
Done!!!
OK i've done what you've suggested
If you look at the read, write and copy times on Aida though, they don't seem great compared to what people on P67 platform have been getting. Do they look right to you? Is there anything more i can do?
I really appreciate you helping myself and all the other guys out on this forum, i know it's a lot of work for you and i think it's really great you give your own time to do it
[/IMG]
Your settings are not quite right.
tWR should be 10, tRTP should be 6. Also set tRRDR to 0. The P67 motherboard is inherantly better for memory benching than X79. Quad channel is complex and adds latency. Z77 is even better than P67.Oh and remember CPU speed does make a difference to these benchies. It should not!!! But I tell ya it does.
It may not be timings though. It could be IMC voltage which is VCCSA. Try tuning this before loosening anything.
