You get a converter or two in the box usually.Matrix said:I this card only dvi? or does it have a VGA connector too?
I read somewhere today it only has DVI which if it does i'm screwed as i was keeping my monitor for a few weeks or months till i get the money saved up for a new one.![]()
Ulfhedjinn said:You get a converter or two in the box usually.
Errol said:So would a sapphire x1950pro be a good upgrade from a x850xt ?
oweneades said:Well it depends heaily on what games you play.
If for example you only play CS:S or HL2 then the upgrade is pointless as the X850XT chews through it easily.
If however you play a much more varied level of games then the X1950 pro would be an excellent upgrade.
Cyber-Mav said:i doubt the x850xt "chews" through hl2 with hdr at a rez of 1600x1200 with 16xAF and 8xAA.
the x1950pro is the better card. or are you saying there is no difference between them![]()
Why take it to the extreme end of the scale?! I just said it could chew through it. LoadsaMoney said:x850's can do HDR in HL2.
Source HDR doesn't use SM3.0 though.charltonfan1 said:oh, thought they couldn't do it properly cos they they dont have SM3.0 or something. ah well, you got my point !![]()
