Which do you think is the best choice: Quad Core 2.4Ghz or Dual Core 3.0Ghz?
The difference is so small, if 2 computers got built with everything identical except 1 being a 4ghz dual, the other a 3.4ghz quad (that seems to be what the current CPU's are getting on normal cooling), and afew people where asked to identify which one is which by running programs (everything like cpu-z etc not allowed, fps showing disabled on games), they wouldnt be able to tell which one is which, until they got to 3-4 threaded programs where the quad would win by far.After searching around a bit it seems that the dual core beats the quad core quite considerably in nearly every bench mark going. The question is, the time software and games that support multiple cores becomes mainstream, will this CPU be out of date anyway?
The difference is so small, if 2 computers got built with everything identical except 1 being a 4ghz dual, the other a 3.4ghz quad (that seems to be what the current CPU's are getting on normal cooling), and afew people where asked to identify which one is which by running programs (everything like cpu-z etc not allowed, fps showing disabled on games), they wouldnt be able to tell which one is which, until they got to 3-4 threaded programs.
Which comes under 3-4 threaded programsThey would if it was video endoding.![]()
Which comes under 3-4 threaded programs![]()
It isn't "close thread" as you have pointed out Stickroad. For the non overclocker the e6850 isn't such a bad option.
Now this depends on what you do with your PC. As well as if you are going to overclock.
Scenario 1: You do not want to overclock and you probably won't utilize dual core 100% on both cores, never mind four cores. In this case it's the 3Ghz dual core for you.
All other scenarios = Q6600.
