check the 6 pin physically fits on 4 pins before you go to the bother of wiring it up.
they have small notches which mean they only go on in a certain orientation - it will save you a lot of hassle.
Thats a good thing to point out , i had noticed how some of the insides of the connections are square while others are circular on one half. And they arent always in the same configuration.
