4 Raptors - best RAID setup for speed?
Man of Honour
20 Sep 2006
Got two atm and two more are coming. I'll be using the partition for the OS, games, burning, Zipping and burning. I want it to be as fast as possible ie RAID 0 but with the extra data I'll be putting on it (have the RAR and ISO files on my 500GB storage drive) I wouldn't mind a bit of redundancy. I want it faster then what it currently is too.
EVGA 680i board with standard controller.
Raid 0? Stripe No Redundancy << Would take this for speed as your board will support it if it does not do Raid 5
Raid 1? Mirror Redundancy
Raid 5? Stripe with Redundancy << I would choose this if your board takes it.
Raid 10? Mirror and Strip with Redundancy.
I however only know one board that does Raid 10, thats the new MSI 775 board.
I know what RAID 0 is :confused:
Yeh? ..... The link I give you is the start of Raid levels........ not what I linked you. Select a Raid value to find out what it is and then investigate into which Raid level you would like. :D
Just got the other two through. Got 4GB of RAM arriving later so once that's in I'll RAID 0 the four of them and just back it up to the 500GB drive as above. Still undecided on Vista or XP though!
