£400 build...
what so to have sli you need an intel cpu and mobo, not always true.
No, the question is, what use is a Nvidia gpu with a crossfire(MULTI GPU) motherboard? might as well save money and buy a single 16X pci-e slot motherboard.
OR DON'T YOU UNDERSTAND THIS?:D
MAYBE I THOUGH I COULD USE TWO NVIDIA CARDS ON A 2 PCI AMD MOBO!
Is that such a crime?
And the 4X speed of the second slot will still suck, and its not really something for a novice to do.
suppose your right on that one, you need the superior power that is my brain
and of course hack a day..... not sure if im aloud to mention that so please correct me on that, don't want a holiday just yet
Oops, look what I started :P.
Thanks for the replies guys, but would a 1GB model of that graphics card be much better for the extra £20 or so?
GTX 460 1GB
btw. the card that you linked to is the SE version, which is not recommended over the standard 460.
It is a standard edition, that what SE stands for, its a reference heatsink.
to the OP, get the cheapest GTX460 768MB you can find, the 1GB isnt worth it for this budget, the money saved can be used to get a cpu upgrade.
oh, i thought it was a different card, thought about getting one for my build and was warned about getting the SE version?
There is only £10 difference between the cheapest 768mb and 1gb. Would you not say that it was worth it?
we now need to know the resolution Cliste will game at? but thats easily answered here - http://forums.overclockers.co.uk/showthread.php?t=18244032
So a monitor in that price range is 1920x1080
the 1GB version from reviews seems to only distance it self at resolutions of 1,920 x 1,200 or more.
