4070 ti vbios problem
5 Mar 2025
Cindeford
Im having an issue with a recently purchased MSI 4070ti Suprim X, when I flick the duel bios switch to the gaiming bios the GPU does not output an image during boot nor when in windows, the GPU works using the silent bios as intended with no issue.
I have audio notifications when I boot into windows so I know the system is reaching the desktop when the gaming bios is selected but it refuses to output any image from any ports what so ever. I am concerned the gaming bios is faulty and that I will have to return the GPU.
Has anyone encountered this problem?
Did you buy the card second hand or new?
Have you tried different display outputs rather than the one you've primarily plugged into the card? Most have 3-4 Displayport and at least one HDMI.
The card is B-grade from OCUK purchased a few days ago, this is a Vbios issue I have tried every output multiple times,It is important to note the silent bios is fully functional on all ports as this rules out many possibilities, however the gaming bios refuses to display an image, im hoping someone has successfully reflashed the gaming bios and fixed their card and could shed some light on how they did it.
I reached out to MSI and they responded
thank you for contacting MSI support.
We're sorry to hear that you're experiencing an issue with your MSI component, and we apologize for any inconvenience this may have caused. We sympathize with your situation and want to ensure a smooth warranty process. For your convenience, please note that the warranty is exclusively offered through our authorized stores and resellers.
To make a warranty claim and have your unit repaired, replaced, or refunded (depending on the available solutions), we kindly request you to contact the store where the item was purchased. They are well equipped to handle warranty claims and will guide you through the process seamlessly.
The problem is though there are no GPU's on the market and I will most likely have to go without a GPU.
