4770k has died, taken mobo with it - replacement advice plz
26 Jul 2010
Wiltshire
4770k has died, taken mobo with it - or not! Updated thread
My CPU/mobo has died, the CPU fan stopped working mid GTA 5 and ended up as silicon toast :'-(
Looking at benchmarks, the newer stuff isn't that much faster, it feels like I'd be buying and not really seeing much of an improvement over what I had? I hate forced buying if there isn't going to be much benefit, thankfully I have only suffered gfx card failure before and that was after 2 years, back in the days of huge performance jumps each cycle.
What to do? Advice please OCUK :(
****Updated****
The PSU was at fault. Confusing considering the CPU fan is still dead, but hey, **** happens :(. Thanks to the suppliers for the exceptional help.
As Death said, unless you bought an OEM version, you can contact Intel and they should sort out a warranty for you.
Just buy a Z97 that fits your needs and you'll be back up and running in no time.
I can't see how I can claim for a burnt out chip that's the result of the fan failing, that isn't strictly a CPU fault?
If I can't return it, I expect the new Intel chips are only 10% faster?
Very surprised that the chips thermal protection didn't kick in. Might still be worth contacting Intel to see what they say.
I would have thought the thermal protection would have kicked in. It might be that you can't power it up at the moment as it's too toasty.
If it has died, do you know anyone who has another CPU that you can test in your board?
And this is why you should always set a critical temperature alarm.
You can normally set this in the bios or download coretemp.
If my fan ever fails and the cpu gets too hot it will let of a crazy alarm, if it reaches critical it shuts down the pc.
If the chip has thermal protection and that failed... It's sort of a CPU fault? Not too sure how you could spin it towards Intel :p
I've found the retail invoice, going to contact Intel and see what they say about it. Worth a shot as I can't see any harm in doing so,hey?
Thanks, I'll update as and when. :)
Good luck, hopefully they'll sort you out.
Still surprised like everyone else that the thermal protection didn't kick in. What motherboard do you have?
do you know 100% that its dead?
done an overnight cmos clear/battery left out? unplug pc from the wall aswell
Section 14.5.1 Catastrophic Shutdown Detector
P6 family processors introduced a thermal sensor that acts as a catastrophic shutdown detector. This catastrophic shutdown detector was also implemented in Pentium 4, Intel Xeon and Pentium M processors. It is always enabled. When processor core temperature reaches a factory preset level, the sensor trips and processor execution is halted until after the next reset cycle.
The mechanism is builtin to the processor, not under the control of BIOS and not dependent on other sensor outside the processor.
Stolen from the Intel forums.
So the CPU's do have an inbuilt function which makes perfect sense. It must be something else :s
I would start by testing the PSU first with a paperclip (Google that before you zap yourself :D)
