Thanks again.
The more I think about it, the more I feel like I haven't actually damaged anything but until I get home I'll still have nagging doubts.
I guess I could have warped the board, socket or the bracket but I only tightened by the tiniest of amounts...no idea how checking the h60 was seated properly then tightening a whisker could get me to such a bad situation.
Also, in bios last night I noticed that at 1.218v I was idling at 50c+ @4400mhz.
On the stock cooler with a poor paste application does that seem alarming to you? This was without the XMP loaded.
Cheers.
you have to be pretty heavy handed to cause damage.
i take it you used a screwdriver to tighten up ?, if you did then unless you push down with a bit of force and/or REALLY tighten the thing to the motherboard to damage it.
what does the chip read at stock settings, in bios and on something like cpu-z ?
thing is with the stock coolers most arn't meant for overclocking, and mmj mentioned that the chips seem to run a touch hot even on stock volts, so see what the stock vcore is and it will give you an idea of how much your adding when your on 1.218.
