4850 temp gradually increased to unusable level, what to do :(
I am surprised people use those cans still you can just buy an airbed pump thing they work very very well
just me or are lots of these starting to die due to newer cards being released ....just a thought ....hope u get it sorted thou .
I had massive temp increases on my 4850, removed hsf cleaned it, put back on and reduced em a bit but within a few days were back up at 110c+ (might have been more tho) at load causing games to crash and pc to reboot
went and bought one of these
dropped temps to 40 idle and 55-60 at full load fan is set at whatever cos its connected via a molex and not to card so ccc fan control dont work but v happy with the result and was a doddle to fit
surely a silly led'd cooler can't be better then the one that the manufacture supply's? what is the heat sink? copper?
If you have a cooler like the above you get a hell of a lot of dust build up just behind the fan which eventually blocks the airflow completely.
A tooth pick & 30 minutes of poking/scraping sorts it out.
haha just dont this with my card and i see what you mean . there wasnt much at all but it settles on the edge of where it would normally blow out the exaust/back.
once clean (took five mins)
went from 100c underload to 50c :eek: there wasnt hardly anything there but i guess its just where it was sitting.
