This video doesn't make the 5600x and 3700x a worthwhile upgrade.
Also I see people on here with beefy GPUs and 5600x CPUs. But a lot of games have a recommend CPU requirements of 8 cores.
Like the recent Metro Exodus Enhanced.
What do people think about that?
Can someone with 5XXX Ryzen cpu and 3080 test this area.?
As you can see from the video the bottleneck is awful for me.
Thanks for the offer. I since progressed a bit from that area but will try to get back to the train tomorrow and save the game then share the save with you.You have a very similar system to my spec. I don't mind trying to run a comparison for you, but I've just checked and don't have any of my previous save games from when I completed it. And to be honest I found Exodus too boring for me to trudge through it again start to finish.
Your more than welcome to send me your save games if thats possible
HDR is great here, nice and bright with vivid colours without any tweaks. Using a PG43UQ monitor.
editHDR is great here, nice and bright with vivid colours without any tweaks. Using a PG43UQ monitor.
Not sure about the EE but HDR used to bug out often in the original. Solution was to keep turning HDR on/off and/or alt-tabbing. Pay attention to the orange in the menu if it changes, it should be more reddish for when HDR works properly.Anyone who is finding the game washed out with HDR enabled, Ive been using Geforce overlay to tweak contrast and it makes a massive difference.
By the time 6 core cpu such as 5600x becomes a problem, we will have way better cpus to choose from, not to mention, be on new ddr 5 ram and so on.
not only minimums but 1600 started to beat the 7600k even at averagesEnthusiasts and reviewers keep making the mistake all the time about core count. Over the last decade people keep having short memories. Its the same with VRAM and GPUs.
The Core i5 7600K thrashed the Ryzen 5 1600 in the Techspot/Hardware Unboxed reviews,but a few years later it just had more consistent minimums overall.
The current console games are intergenerational titles designed to mostly run on the previous generation,and even with that generation with 8 Jaguar cores we went from 4C/4T being the sweetspot to 6C/12T being the sweetspot in 3 years. So in the next 2 years or so I can see 6C/12T CPUs starting to have more issues. But by then many here who bigged up the Ryzen 5 5600X will have changed the CPU.
However,for most average PC builders,CPUs can be easily kept for upto 5 years or more,hence why SB/IB/Haswell/Skylake based systems are still common. Its not always about trying to win the early benchmarks. It helps to have extra in the CPU tank.
If we go back even further most reviews had the E8400 beating the Q6600,but again the latter lasted longer with more consistent minimums.
The thing is that the Ryzen 7 5800X dropped in price quite a bit,and the Ryzen 5 5600X has not dropped in price,or even gone up. So realistically,it is still better to spend the extra on the Ryzen 5 5800X,especially part of motherboard bundles.
There were many instances were you could get a Ryzen 7 5800X for only £50~£70 more than a Ryzen 5 5600X. Sure you need to budget in a cooler,but my experience of using the Wraith Stealth,Spire and Prism was that the Stealth was marginal anyway.
Even the Ryzen 7 3700X could be had for closer to £200 if you shopped around,and the AMD Wraith Prism RGB was selling for around £30 secondhand too.
The thing is many here don't keep their CPUs that long,ie,a year or two and then upgrade. IMHO,if you intend to keep a CPU for 3~5 years with a good GPU,I wouldn't touch the Ryzen 5 5600X with a bargepole. Its a false economy. Find the extra cash and get a Ryzen 7 5800X.
Plus if you really are budget limited something like a Ryzen 5 3600/Core i5 10400F/Core i5 11400F are significantly cheaper overall and the rest is better spent on the GPU. Even the Core i7 10700F/Core i7 9900 were on clearance a while back at close to £200ish if you shopped around.
