5 devices, 2 IDE sockets
28 May 2003
Hi,
I need to add an additional hard-disk to my rig, but since i have two IDE sockets and already four device's i am not sure how to proceed. Two hard-disks are on one cable, and the other cable has two CD-drives.
I have a Kudoz 7E/333X motherboard (http://www.qdigrp.com/qdisite/eng/support/manual_e.htm) which has 2 IDE/ATA sockets - i believe in does not have any SATA options, but this is at the limit of my understanding!
Can i connect a (new) DVD drive and the new hard-disk to the same IDE cable?
Help appreciated!
Crawf
P.S - Off to search the forum history for what £40 HD, and £20 DVD drive is best.....
I believe you need a card that sits in the PCI slot and will give you more IDE channels. Suprisngly OcUK is down for me right now so I cant search a product.
You can buy a card, quite cheaply, that will support 2 IDE drives and 2 SATA drives.
(Then you just have to decide what drives to buy.)
Hey,
Down of me too - OC must be having trouble with their new website.
If i remove one of the CD drives can i connect a HD and the remaining CD to the same IDE/ATA cable?
2 devices per IDE cable, it doesnt support more then that.
An ide port is capable of running 2 IDE devices.
Anything more requires an expansion card, wether that be IDE or SATA. This was explained above, but i'm saying it again, lol........
Personally i'd buy a bigger drive rather then add more smaller ones if thats what you are doing, 250gb is £40 - £50 these days.
Would someone mind looking at the manual link to tell me if i have a SATA connection - I don't know what they look like!
Are SATA opticals expensive?
Cheers
Hey,
Cheers for looking!
The PCI/ATA converters seem pretty expensive - >£20. Wonder if a USB2 external HD might be a better solution.
Or, can i have a HD and CD on the same IDE cable?
