It should realistically drop to about 40 then about 2 seconds later back to 30. If it's taking a while that tells me either the cpu is dumping a lot of heat or the pump is not carrying the hot water away fast enough.
Especially if you just run the test for a few minutes. Sounds to me like the pump is not running correctly.
1.25v is fine. 1.35v-1.4v is about the limit you want to put on the chip for 24/7.
Do you have an air cooler anywhere to test?
