what settings are you running? PBO with curve optimiser? Best i can get outta my 5900x seems to be around 13,980 mark with curve optimiser on.Just ran a test with the 5900x
I have let asus do an auto OC via BIOS - 13500ish. ryzen master auto OC- same. PBO on - lower!. PBO with curve optimiser at -10 per core, 200mhz boost and 13980 is about as good as it gets.
Am using a Liquid freezer 2 360 with Push Pull, and temps seem absolutely fine, so im assuming thats not the issue. Doing my head in tbh!
