If it's solely for gaming then you could get a 7800X3D, even just dropping in a 5800X3D would be a worthwhile upgrade.hey guys,
im currently running a 5900X and wondering if upgrading to a 7900X3D or 7950X3D is worth it or not?
it will solely be for gaming, but I do multitask a lot with various program, I have 64gb RAM atm. But Im sure 32gb DDR5 would be fine?
5800x3d is a simple drop in option tooit will solely be for gaming,
I would wait for Zen 5 now, as a 5900X is still more than good enough. I did not notice the jump from a 3900X to a 7950X in games. I did notice the CPU jump and the drop from 64GB to 32GB for work.
3900x is a good notch down from a 5900x though for gaming. IPC and just newer tech.It really depends on the circumstances and games.
For me going from a 3900x to a 7800X3D saw some titles go from 120fps to 220 and that was only on an RTX 2080 at 2560x1440.
I can easily see how some games wont see any benefit however and unless you really need to change I'd stick it out on the 5900X.
For now, 5900x does everything I want and need.
Same here. New chipsets and Zen 5 seem worth the wait.Am in a similar position and decided that it would be best to wait for Zen 5 - Hopefully this is the right choice!!
Interesting. Out of curiosity what memory did you have with your 5800x and what timings was it running at?I've just gone from a 5800x to a 7950x3d with a 7900xtx - I only play at 4k 120hz vrr on an LG OLED, there's a big difference in how smooth the games are now, not max frame rates (in most things anyway although some show improvements) - the main difference is the drops are gone.
Worth the price for the upgrade? For me personally, yes, but I got the new parts after finding some bargains, certainly wouldn't pay RRP.
4 x 8gb Patriot viper steel 4000mhz running at 3600mhz dailyInteresting. Out of curiosity what memory did you have with your 5800x and what timings was it running at?
