£600-£700 build.
Right i am ordering it tonight, I already have a dvd drive and a monitor, and id like some speakers and a card for wireless internet, so could someone please spec me, got £700 no more thanks :)
ooh my god hahaa sorry about that i didn't read it properly, thanks a lot i'll order it now, do you know on average how long postage takes?
Assuming everything is in stock, then the items get picked hopefully tomorrow, then it depends on what delivery option you select.
As I expected, I've run into some problems; all the parts are plugged into the power supply and the motherboard, but there are some wires left without parts to go to. I don't know much about these wires because the power supply didn't come with a manual, anyway when i try turning the PC on it comes on for a split second and goes off, all the fans and LEDs come on too for that split second, anyone got any ideas?
Ok,
The motherboard needs a 24pin and a 8 or 4pin ATX plugged into it (near CPU socket)
The HDD needs a SATA power from the PSU and a SATA data from the motherboard White SATA port
The DVD needs the same, but use a Blue port as they are SATAII.
The GFX card goes in the top big slot and needs a 6pin PCI-E power cable from the PSU.
The monitor I am currently using is VGA, so I tried running video through the motherboard until I got a new one but nothing comes up on the screen when I power the computer up, so I tried using the DVI to VGA adapter that came with the card to run the video through the card and still nothing. Do I have to somehow install the motherboard and the graphics card before the screen works?
The motherboard has a DVi-D (digital only) so you cant use an adapter to get the monitor to work on it.
Remove the GFX card and connect the monitor directly to the VGA/Dsub port on the board.
Is there a picture?
I'm saying remove the GFX card and see if you get a picture from the motherboards display output (the VGA/Dsub connector)
Its very likely that if you do then you need to update the BIOS (many people have had to do this with that board)
