£600-£700 build.
Okay everythings working fine apart from the computer won't detect the video card, or not that I can tell anyway. I've looked for drivers and it said that the graphics card could not be found..Help? hahaha
Can you boot into safe mode and alter the resolution to something lower?
Thats if the Nvidia display driver loads in safe mode that is? which I dont think it does.
It should do.
It will do however, you should select "Low resolution mode" not Safe mode as then you can just up the resolution as use as normal, where as Safe mode will need a reboot after settings change and won't load the graphics drivers at all.
