Its just the button in your post, click on it, login and the MM will appear when you meet the criteria.
Odd that shivy011 is suggesting the MSI lightening, just a few days ago he was convinced the GTX970 was a better choice
http://forums.overclockers.co.uk/showthread.php?t=18643516
Where does the DVD drive go?HO HO HO
I've got to make 1 mistake at least - the case is just a placeholder for whatever the OP wants (roughly £50)Yeah he can afford more, but he just wants to start with lesser and upgrade as and when he sees necessary basically.
Also, can save money on the PSU bringing that build to under £1k as I'm giving him my 850W Cooler Master SilentPro 80+ Bronze (a few years old but it's powering my PC fine at the moment - no coil whine on my G1 970 either when under stress so happy days. I've got a brand new V1000 lounging around so that'll go in my rig when he gets his!) Could also swap out that USB adapter for the Wireless Card I put in (I've got it, works like a charm
Does the PSU have 2x 8pin and 1x6-pin power connectors? It should do, but just double check
Also do change the case as stulid pointed out it has no 5.25" bays or get an external USB DVD drive as optical drives aren't used all that much anymore? Unless he has a specific need for one
The wireless card I suppose is your choice, dongle is probably easier should you need to put it into another PC quickly, and might be easier to set up? Not sure about this however
HO HO HO
