6900+ Nova bench direct3D11 help.
4 Feb 2021
Newcastle, UK
So recently I built a new machine quite a beast.
got a really good score on nova bench a few weeks ago, howeve now the direct3D11 score is very under par compared to two weeks ago I’ve tried fully reinstalling drivers and removing them all properly in safe mode.
It’s really annoying me as it’s a beast of a graphics card.
Sapphire RX 6900+ XT
Please see attached screenshots for comparisons and if someone can shed some light please do, I’ve tried primary mode, software mode everything on cpu and it’s just nowhere near what it was a few weeks ago.
https://~ibb.co~/kmMxYN2
https://~ibb.co~/qymwKTP
Have you made any changes to the system in that time? It looks like the graphics card is running at a lower clockspeed than it should be.
I'd install GPU-Z (https://www.techpowerup.com/gpuz/) and check the graphs on the second (sensors) tab, this should show the clocks in real time and may also tell you what is limiting it (temps/power etc).
Have you noticed any change in performance in games?
Also could you list the full system spec?
Thanks for the reply. I installed cpu-z awhile ago.
howver I’m going to be completely honest I’m a total Novice!
Games run fine howver csgo after a game or two there is a lot of micro stuttering, player models jittering flash bangs jittering.
cod black ops Cold War runs fine all ultra never drops below 200fps.
if You can give me some ideas or tips or suggestions to post on here with instructions I will try.
many help is very much appreciated
Corsair 500D Obsidian RGB SE
AMD Ryzen 5 5600x
Sapphire Radeon RX 6900 XT Nitro+ OC 16GB
Corsair RM750x
Corsair Vengeance RGB PRO Black 16GB
Corsair H60i RGB Pro XT
MSI MPG B550 GAMING CARBON WIFI
WD Blue SN550 1TB NVME M.2 2280 PCIe Gen3 SSD
Samsung Mx500 SSD
MSI OPTIX AG32CQ Curved 144hz
Samsung 27” Secondary Monitor
GPU-Z result, this is the advanced tab which I presume shows the settings it runs at?
like I say I’m a total novice, but the gpu seems to be running far less than it was a few weeks ago. I’ve not adjusted any settings on it, trixx software is installed I’ve tried changing the bios switch from one to 3 which runs from the software, and still no difference either way. Uninstalled the graphics card drives with the proper programme that removes everything even registry files etc.
anyways here’s the advanced tab from GPU-Z
https://~ibb.co~/6vPps8q
ok, well AMD do list the power requirements as 850w for the 6900xt, so that's a possibility, but the consensus here was that 750 should be enough. I also vaguely remember another member with an RM series PSU having issues in a thread recently. (edit: can't remember if that was nVidia or AMD and also have no idea whether they resolved it)
I should have asked this initially - are the power connections on the card using separate cables to the PSU for each one? If they are using a shared cable that is the most likely cause.
It could also be some software messing with settings - I'm not sure if Trixx does anything like that but I know the MSI Dragon Centre software can apparently mess up CPU settings etc (do you also have that installed for your motherboard?).
It's personal preference but I'd probably avoid the software control and use one of the other two BIOS options at least until resolved.
also, you can see from your screenshot that your card is only hitting 1119MHz, however as you said this is CS:GO I'm not sure what to take from that as it's a very CPU limited game especially with a set up like yours - I'm not sure I'd expect much more usage!
First thing is first.
Lovely computer, nice build there awperator.
Secondly, the PSU is way out of spec for that gfx card.
Consensus is, having owned at 6900xt red devil btw, that 750W PSU just aint good enough for a 6900xt. Especially if you want to push it.
Big navi has high spike load, it might be efficient and use "less power" but big navi spikes hard and fast, higher than the 3000-series.
I have seen many people have instability with lower power supply's with navi and ampeer.
Thank you for taking the time to give an in depth reply it really is appreciated.
dragon centre I never installed I read all about it before I built the machine and avoided it, I do rmeneber a lot saying I should have for the 750. I will check the power connections and get back to you
But I’ve not overclocked anything or changed any settings except xmp profile in bios. It’s really getting to me as it was a really expensive build
never used nova bench what ever that thing is.
Download OCCT, run CPU + GFX test for an hr and see if its stable first, my guess it will probably crash.
Is your card set on performance mode? Therefore its overclocked out of the box from AMD spec, with higher power targets.
Read the spec for your card.
https://www.sapphiretech.com/en/consumer/nitro-radeon-rx-6900-xt-16g-gddr6
System Requirement
  • Minimum 850 Watt Power Supply
  • 2 x 8-pin Power Connector.
  • PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard.
  • Minimum 8GB of system memory. 16GB recommended.
return your corsair 750 and get this, done
https://www.overclockers.co.uk/msi-...s-gold-certified-fully-modular-ca-00j-ms.html
£130 great little psu
its like driving a car that states you need tyres minimum load 96 and you stuck a 92 load tyre. Your build is out of spec, mate.
I’ve tried all the settings performance, silent in case it was drawing to much power.
you definitely think it’s the PSU?
System Requirement
i cant tell you definitely nothing mate, i am sorry, without being there.
But I would not be happy running a 6900 AIB on a 750W.
There could be a lot of different reasons for the drop in performance.
but with the limited info that you provided, the only thing that stands out is the PSU, which is outside of manufactures spec, and is under powered.
Do a step by step elimination. Check the memory, cpu make sure its not throttling, video card and then check cpu + video card can work at full blast with your psu.
I'm also leaning towards the PSU not being up to the job and agree with Dontrocktheboat that I wouldn't be comfortable with 750.
was also going to suggest OCCT, even though you haven't overclocked anything yourself, as said above everything is running very aggressive boost algorithms these days so it is running beyond spec.
The OCCT power test will put everything at full load so would expect it to fail if the PSU is the issue.
my choice for a budget option would be this
https://www.overclockers.co.uk/seas...w-80-gold-modular-power-supply-ca-06t-ss.html
But with how much you've spent on the rest, I'd be looking at a good quality 1000-1200w gold or platinum unit, as it will run quieter and more efficiently if it's not so near it's max wattage.
Brand wise I would rank seasonic as top tier with superflower, be quiet, silverstone all having solid reputations.
Corsair are a bit varied, their more budget offerings aren't great but ok for the price. The higher end lines such as RM and HX are generally better.
I was going to link some but I've just had a look and it seems it's still impossible to buy a good 1k+ unit :(
I appreciate everyone’s replies I really do, as I say I’m a novice when it comes to problems with computers, I built this myself I have some knowledge but not in this area I’ve hammered google these past few days and tried all sorts.
I will try the various options, I got the psu from Amazon as I had a gift card on it! It was 119 for the white rx750 special offer, and wanted the white cables however the 850 and above aren’t in stock! They’ve acceded a rma and gave me a gift card to the value once they receive the item and I’ll have a look then.
Im kind of limited to funds now as I need major surgery this was a new build for my daughter as it’s her gcse year and going to collage and also loves gaming like her dad! So I’ve not much time before my major acdf surgery and limited to time I can attempt things as often in out of it on all the medication I’m on.
much love guys I’d buy you a beer if I could!
no problem :)
I'd definitely check the cables as I mentioned before.
Prior to this generation of cards I would have said 750w would be fine but this generation really do have crazy high spikes from what I've seen online.
other useful tools I always install are HWMONITOR - https://www.cpuid.com/softwares/hwmonitor.html or HWINFO64 - https://www.hwinfo.com/download/
I know it's a lot of info and can be intimidating to look at at first, but will tell you pretty much everything you need to know about your system.
leave either of them (or gpuz) running while you play a more demanding game such as cold war and you should see the GPU clocks going up well over 2000MHz (I think with that card, don't quote me haha!)
The GPU clock graph in GPU-Z should be solid and not have white lines all through it (a couple can be ok if loading the map etc)
If it all looks good and it's playing OK, you may not actually have a problem, similarly if your CPU is pegged at 100% in CS:GO (due to not being able to keep up with the 6900), that could explain the stutter.
Like dontrocktheboat I've never heard of Novabench so can't comment on that.
Best of luck getting this sorted and with your recovery :)
