It won't artifact on legacy drivers as there is next to no power being used on the card at all.
Dodgy gpu memory probably, only other thing it could be is if you have not seated the card properly or your psu is not up to the task/faulty.
As you said it happens on the dektop too, then it will more than likely be doing it on all games.
Try running Heaven benchmark and take some screen shots and contact customer support, they should sort you out with an rma as I don't think it's driver related.
