6950 RMA...
Permabanned
29 Jun 2010
England
Sent my HIS 1GB 6950 back to Overclockers because It has been artifacting. They've tested all of it and said there's nothing wrong with it, I've had lots of problems with artifcating on these games: WOW,CS. Now they've returned it to me saying there's nothing wrong with it. What can I do to stop the artifacting.
No they emailed today saying they will send it back to me with a charge of £10.00 for testing it. Please I need some help what could the problem be?
The thing to do first is to try it again in your machine, making sure it's fully seated in the PCI-E slot and go from there. If it's still doing it then I would suggest updating the drivers and trying it again, or downgrade them just to check to see if it's a bug with a specific driver set. Also if you have access to another machine to try it in I would try that as a last resort.
If it's still doing it then get some videos of it doing it and forwarding them to OcUK and see what they say.
Overheating - make sure you leave the side of your case off and the room is cool.
Software - try a fresh windows install.
Other hardware - try it in another PC.
How do I check if it's overheating though? What program to use to see CPU and GPU temps?
GPU-Z is good.
However, if it isn't overheating for the OcUK testers then you probably need to make sure that your case airflow is decent.
Without directly saying anything is bad about OcUK's testing procedures, it is possible that your card is actually faulty. That said, you still need to eliminate other possibilities.
Are they allowed to charge you £10?
Pretty shabby tbh.
It's clearly stated on their website.
Testing. All returned items not returned in accordance with the Distance Selling Regulations (2000) are tested by Overclockers UK technicians. Any item found to be not faulty will be subject to a £10 +VAT charge if collected or a £10 + return shipping + VAT charge if shipped back to the customer. You will be notified by e-mail before any non-faulty goods are returned to you. This does not affect your statutory rights.
My system specs are as follows:
Amd 955 Black edition from 3.2 overclocked to 3.61ghz
8gb XMS3 1600MHZ corsair ram
Seagate Barricuda 500g 7200 RPM
HIS 1GB 6950
Corsair TX650W
Coolermaster Elite 334 - http://www.coolermaster.co.uk/product.php?category_id=3586&product_id=4253
A massive CPU cooler : Akasa Apache is attached to the CPU cooler.
Coolermaster Fan on the backplate obviously came with the case.
