£700 base unit build for gaming
27 Nov 2003
Loughborough
Hey all,
I'm not really feeling this spec at all but I've been tweaking one a mate did on a competitor site to get the bits from a decent shop for him :o
His aim is to get another HD 6870 for chrimbo and crossfire it so the graphics are quite weak. Can anyone tweak this around so it stays in the £700 budget and has a bit more oomph for Bf3? :)
He doesn't fancy overclocking just yet either so I left the retail cooler in there.
Ta muchly.
Here you go, re-done the spec:)
Did you need an optical drive?
Hmmm I'll go with nope for the meantime, I built his last system about 3 years ago and optical drives didn't move along too much since then (totally forgot the psu though, I'm used to thrashing mine).
I hoped you'd appear, a spec thread isn't done till you've posted in it. :p
Looks like a good choice to me, I'll go with that when he shows up with the cash tonight.
Thanks all. :)
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £173.99
OcUK GeForce GTX 460 768MB GDDR5 PCI-Express Graphics Card - OEM £85.99 £171.98
Asus P8Z68-V LX Intel Z68 (Socket 1155) DDR3 Motherboard
£81.59
Microsoft Windows 7 Bundle - Home Premium 64 Bit
£68.40
Options applied to the above product:
Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX) £47.99
(£39.99) £47.99
(£39.99)
OCZ ZS Series 750W '80 Plus Bronze' Power Supply £56.99
(£47.49) £56.99
300 Three Hundred Ultimate Gaming Case - Black £45.98
(£38.32) £45.98
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9B) £42.95
(£35.79) £42.95
Cooler Master Hyper TX3 CPU Cooler (Socket 754/939/940/AM2/AM3/775/1155/1156)
£705.85
£81.59
£68.40
(£39.99) £47.99
(£39.99)
(£47.49) £56.99
(£38.32) £45.98
(£35.79) £42.95
£705.85
Two GTX460's? wont work;) no SLI support.
Thanks all. :)
If he has a DVD drive and its SATA and not IDE? then your ok.
Its a lot of effort to go round and check :p
There is £20 delivery charge on your spec I can knock out anyway to add a sata dvd-writer. :)
Well reminded though, I wouldn't have.
Thanks all. :)
would have said knock the cpu to oem(unless you need the 3yr warranty) to save another £10(was £17 saving just the other day) and get http://www.overclockers.co.uk/showproduct.php?prodid=HS-005-AN&groupid=701&catid=57&subcat=1395
but its pre-order so not sure if your friend can wait like a week/week and a half and it puts it ~£10 over budget.
