I think brands are usually defined on warranty and customer service, so if you want a decent warranty length, then go with a brand with a good warranty and that is also known for good customer service.
Which are?
And as for the RAM size and cooling? I dont mind spending premium for a single card.
Hey guys.
Heres my current specs.
I7 930 OC'd to 4Ghz watercooled
6GB OCZ Reaper Ram. Triple Channel
2 Vertex II's Striped.
GTX 280.
28 Inch monitor running at 1920x1200.
Antec 1200 with Antec CP1000 Power supply.
Essentially my GTX 280 has been failing for the past few months to deliver and I think it is time to move on from it. It overheats very easily whilst the rest of the system is running cool.
Essentially I am looking for a single card solution, I play lots of Physx enabled games and benchmarking.
I have £700 to spend, I do NOT want to SLI at this time though I will in the future. I want to have a working life of about 3 years running near to ultra high settings. I will only use one monitor running at 1920X1200. I may start playing games in 3D on my TV at somepoint. I like OVERKILL and ultra smooth gameplay.
Ideas?
I've got a pair of 8800GTX's with your name on it Rob You know you want them
Go 6990, then afterwards you'll have more sense than money, rather than your current situ... £700 on a card, dear me
We have advised you to stay the hell away from the 590...if you won't take our advise seriously, I don't think anyone would bother much more in trying to help you...Just had another thought, I am not really into overclocking gfx cards. one GTX 590 is better then one GTX 580. 2 GTX 590's are better (slightly) then 2 GTX 580's. I know that 3 GTX 580s are definitely better then 2 GTX 590's. But I really dont want to use 3 cards.
If I am not overclocking and dont have future plans for 3 cards (Only 2) Then technically the 590 is a better purchase? The 590s only explode if the card is overclocked right?
Simply put, no matter what option you should go for, one thing for sure is under no circumstance should 590 be part of the equation.
Hey guys.
GTX 280.
Ideas?
